Drywall Under stairs & around stairs
mgj318
Thanks.
Can you post an image of what you want to do -- or what you have and a bit better description? There are multiple conditions that might be described as "Trying to make triangular shape under the stairs", and they all require doing something different.
I did this in an older trial version of Suite, so it should work for you.
The blue is a soffit. The gray above is a Wedge Shape from the library. Place them in plan, take an elevation and use the edit handles to shape.
I used a Pass Through for the opening -- see the Shape settings.
Make a copy of the stair. Open it and set its width to 3". Center it over the wedge and change the number of treads -- make it shorter.
Change the baluster material on the main stair to Opening No Material, and turn off the right side railing.
Change the newel on the skinny stair and you should be close.
