HewnedCabins Posted November 21, 2017 Share Posted November 21, 2017 Hello All, Intent, Accurately layout my house so I can remodel/design a new second floor. My home is a cape cod story and a half. I am having issues getting the roof to layout correctly. I need to get it accurate for room layout purposes. I have attached a few pictures of the actual house and the current state of my layout. My biggest issue is the front layout, between the entry roof line and one of the hip line intersections. I am using HD Architectural 2018. Any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
HewnedCabins Posted November 21, 2017 Author Share Posted November 21, 2017 Thanks for the quick response. I have uploaded the plan file and other exterior pictures. Updated Floor Plan.plan Link to comment Share on other sites More sharing options...
Jo_Ann Posted November 21, 2017 Share Posted November 21, 2017 I was able to get this to work (with auto build roof) by adding a 3rd floor. 1st add the second floor over the entry, but make it shallower, and extend it into the room to the west. Then build the 3rd floor (blank plan) over the 2nd floor entry room, and align the walls. Set the gable wall roof. Next, lower the ceiling heights of each ENTRY room, beginning with floor 1. Ceiling heights are represented by the colors shown: floor1-green. floor2-orange. floor3-blue. attic-gold. You just need to play with your settings until ALL the roof is correct. ONLY THEN should you turn off auto build roof, and delete a lot of the unwanted extras, and raise the intended ceiling height. Don't be tempted to start adding interior walls and other stuff until the entire roof is correct! Link to comment Share on other sites More sharing options...
HewnedCabins Posted November 22, 2017 Author Share Posted November 22, 2017 This is incredible, thank you for the help. I am definitely going to dissect this. Link to comment Share on other sites More sharing options...
HewnedCabins Posted November 22, 2017 Author Share Posted November 22, 2017 I am having an issue setting a floor over just the entry. And when I do a 3rd floor, creating the walls over the entry it won't let me access this room to adjust the ceiling height. Again i appreciate any help. Updated Floor Plan 1.plan Link to comment Share on other sites More sharing options...
ThamosRoamer Posted March 9, 2024 Share Posted March 9, 2024 On 11/21/2017 at 12:30 PM, Jo_Ann said: I was able to get this to work (with auto build roof) by adding a 3rd floor. 1st add the second floor over the entry, but make it shallower, and extend it into the room to the west. Then build the 3rd floor (blank plan) over the 2nd floor entry room, and align the walls. Set the gable wall roof. Next, lower the ceiling heights of each ENTRY room, beginning with floor 1. Ceiling heights are represented by the colors shown: floor1-green. floor2-orange. floor3-blue. attic-gold. You just need to play with your settings until ALL the roof is correct. ONLY THEN should you turn off auto build roof, and delete a lot of the unwanted extras, and raise the intended ceiling height. learn more roof repair Annandale Va Don't be tempted to start adding interior walls and other stuff until the entire roof is correct! I really appreciate to you on this quality work. Nice post Link to comment Share on other sites More sharing options...
