mschoonmaker Posted November 4, 2017 Share Posted November 4, 2017 Right or wrong, I created a terrain plot as one file, then created a home plan in another file. I can see that I can select the terrain, then copy/paste that into the home's floor plan. The terrain data has the proper orientation N/S/E/W, and I want to move the home design into the terrain plot, but need to rotate the entire home (floor) plan to fit into the terrain plot. (the front of the home and garage must be oriented to the arc of the cul-de-sac) Any thoughts or suggestions? thanks! Link to comment Share on other sites More sharing options...
solver Posted November 4, 2017 Share Posted November 4, 2017 See this post for some ideas. If you choose to rotate the terrain, you could view the angle of one of the lines, then use Transform/Replicate to rotate it. Link to comment Share on other sites More sharing options...
mschoonmaker Posted November 4, 2017 Author Share Posted November 4, 2017 thanks. After reviewing posts, I chose to keep the floor plan due north, and rotated the terrain layout to be in alignment with the floor plan and added a North compass pointer. Seemed the more preferred way to go. Link to comment Share on other sites More sharing options...
