Rotating floor planks
mschoonmaker
This is a common problem easily solved. Each material has a dialog box where it can be edited as to size, direction, color, and angle. Each material is defined for each main camera type: Vector view= lines and colors and Standard=that shows materials across 3D faces of objects. In the case where you need the same material in two places, running two different angles then one makes a "Copy" of such a material for this purpose. Each copy can be set to run a different angle or direction provided it has a slightly different name in the plan.
Data on this can be read here: https://www.homedesignersoftware.com/search/?default_tab=support&q=custom+material
