mschoonmaker Posted October 29, 2017 Share Posted October 29, 2017 I pulled the tile (6"x36" planks) from the Manufacturer's catalog, but when I go to Doll House View, the flooring is running across my halls, instead of lengthwise. ow would one rotate the flooring please? Home Designer Architect 2018 Link to comment Share on other sites More sharing options...
DavidJPotter Posted October 30, 2017 Share Posted October 30, 2017 This is a common problem easily solved. Each material has a dialog box where it can be edited as to size, direction, color, and angle. Each material is defined for each main camera type: Vector view= lines and colors and Standard=that shows materials across 3D faces of objects. In the case where you need the same material in two places, running two different angles then one makes a "Copy" of such a material for this purpose. Each copy can be set to run a different angle or direction provided it has a slightly different name in the plan. Data on this can be read here: https://www.homedesignersoftware.com/search/?default_tab=support&q=custom+material DJP Link to comment Share on other sites More sharing options...
KirkClemons Posted October 30, 2017 Share Posted October 30, 2017 More specifically, this article should help: https://www.homedesignersoftware.com/support/article/KB-00863/rotating-the-direction-of-a-material.html Link to comment Share on other sites More sharing options...
