electron1kid Posted October 21, 2017 Share Posted October 21, 2017 Hi, I live and Malta and we have flat roofs. How do I create a flat roof please? Link to comment Share on other sites More sharing options...
DavidJPotter Posted October 21, 2017 Share Posted October 21, 2017 Look in your own software program in the "Build Roof" Dialog "Roof Styles" tab of that dialog. Where you will find basic instructions on how to pre-setup for auto-building most common roof styles in ANY Home Designer title or version. The instruction you will be looking for is for a "Shed Roof", in order to get a flat roof you simply order the "Roof Pitch" for the "Shed" roof to be "zero inches" in pitch. Another simple way to create, automatically a "flat" roof is to set the "Roof Pitch" input box to "Zero inches in pitch" or some value like "1/16" in 12" as the pitch, this will then give you a reasonable looking flat roof as a result. You might also want to change the surface material to something more appropriate for such a roof, like asphalt or some such material. DJP Link to comment Share on other sites More sharing options...
