automatic room dividers being created
Ineedhelp
I have noticed that sometimes when drawing a plan that a room divider will automatically be created and I can't delete it. It will just happen when I am drawing a wall in my plan. I am only trying to create a simple floor plan and don't need a roof design so don't have a roof showing but these dividers are annoying and can't figure out how to draw without them being created even when I don't want them.
This may be what is happening (see attached image): when you draw a  room inside of a room, the software is pre-programmed to connect the inner room with an exterior wall by default. The dialog I am showing you is from Home Designer Pro 2018 under Edit-Preferences-Architectural but this is rather standard through out Home Designer titles presently. I know it is annoying when you do not know why the software does something of an automatic nature. Just take the time to find out before becoming too annoyed, OK?
