CheifUserE Posted August 24, 2017 Share Posted August 24, 2017 I'm trying out how to get the toolbar that's usually at the top of the screen back because It recently disappeared and I cant remember what it was called to find anything. Anyone know anything of how to get it back. The tool bar has all the options on it. Landscape, Walls , Stairs, Doors, etc I've tried to use <view I've pressed everything on their doesn't work. Below is what I need help getting back. Link to comment Share on other sites More sharing options...
CheifUserE Posted August 24, 2017 Author Share Posted August 24, 2017 2 minutes ago, solver said: 1) Please fill out your Signature -- see below. 2) Did you try what Chopsaw suggested? Did you close the program and restart? If these things do not work, and you are using a current version, try contacting support. -------------- It helps if we know what title (Suite, Pro etc) and version (2014, 2015 etc) you are using. You can add this info to your signature by clicking on your user name at the top right of the page, click Account Settings, then Signature on the left. Doing so makes it always available, and this info is often key to providing a good suggestion Resources for self help: The built in Help System (always a good place to start) Getting Started Knowledge Base YouTube I tried what chopsaw said didn't work either. I've tried contacting support and looking up videos. They told me to do the same things. I tried and it didn't work either. In using " Home Designer Suite 2016" Link to comment Share on other sites More sharing options...
Robborito Posted August 25, 2017 Share Posted August 25, 2017 Just toggle the Views\ Toolbars button?? Works on my version... Link to comment Share on other sites More sharing options...
