dbritti Posted August 14, 2017 Share Posted August 14, 2017 Hello! I'm using Home Designer Pro 2018. I need to build an enclosed closet that only goes 84" high in a room with 108"H ceilings. I could do it with sofits or panels but I need to be able to "install" louvered doors. How do you customize the wall height? Half walls and regular walls are bound by ceiling height rules. Then can a "roof" be added to close the top at 84"H which will provide shelf space? THanks for all the expert help! Denise Link to comment Share on other sites More sharing options...
Jo_Ann Posted August 14, 2017 Share Posted August 14, 2017 Set the half wall 'balusters' to be 84", change the rail to drywall, and install the door. Use a box shape or custom counter top for the top shelf (soffits don't work well). You can add molding to a custom counter. Link to comment Share on other sites More sharing options...
KirkClemons Posted August 15, 2017 Share Posted August 15, 2017 Try the shelf ceiling feature: https://www.homedesignersoftware.com/videos/watch/2503/creating-a-plant-shelf-ceiling.html Link to comment Share on other sites More sharing options...
dbritti Posted August 16, 2017 Author Share Posted August 16, 2017 THANK YOU EVERYONE!! The shelf ceiling seems to be the easiest solution and handles the louvered door at any size. Thanks again! Link to comment Share on other sites More sharing options...
