deWayne67 Posted August 10, 2017 Share Posted August 10, 2017 I need brick wrapped arched openings for the front porch. The brick texture doesn't match when using the Object Painter tool. I've also created a custom wall type but the texture of each side still looks different. Is there a workaround? Link to comment Share on other sites More sharing options...
solver Posted August 10, 2017 Share Posted August 10, 2017 Did you start this plan in an earlier or different version of Home Designer? One texture is using a Bump, or Normal map. The other is not. See the Adjust Material Definition tool. Link to comment Share on other sites More sharing options...
deWayne67 Posted August 10, 2017 Author Share Posted August 10, 2017 I started this design in HDP 2018. I've been using Chief Architect 9.54 since 2004 and decided to get HD Pro 2018. I'm quite impressed with it! Only drawback so far is no Arch D (24 x 36) layout capabilities... I'm trying to find the screen you took a pic of. Where is it located? Link to comment Share on other sites More sharing options...
solver Posted August 10, 2017 Share Posted August 10, 2017 On 8/10/2017 at 7:27 PM, solver said: See the Adjust Material Definition tool. Expand Link to comment Share on other sites More sharing options...
deWayne67 Posted August 10, 2017 Author Share Posted August 10, 2017 Found the tool. Both files appear to be identical (jpg) Any suggestions? Link to comment Share on other sites More sharing options...
solver Posted August 10, 2017 Share Posted August 10, 2017 Post the plan, or just a simple one with one wall showing the difference. Link to comment Share on other sites More sharing options...
deWayne67 Posted August 10, 2017 Author Share Posted August 10, 2017 Here is a section of my plan. I added the double brick option also. Thanks DeWayne-test-plan-hometalk.plan Link to comment Share on other sites More sharing options...
solver Posted August 10, 2017 Share Posted August 10, 2017 I used the Material Eyedropper to select one brick and paint the other brick, which changed to match. Don't know how, but the rough looking brick is using a Bump Map and the other is not. From your screen captures, Pro does not let you set Bump Maps for a material. Link to comment Share on other sites More sharing options...
deWayne67 Posted August 10, 2017 Author Share Posted August 10, 2017 The Material Eyedropper tool corrected the problem for me also! Thank you for your help!!! Link to comment Share on other sites More sharing options...
