Keith_K Posted September 18, 2014 Share Posted September 18, 2014 In a council chamber on my plan I created two areas of public galleries by using the stairs tool i.e. making them wide, with wide treads and10mm risers - the latter to give those sitting behind the first row which is at floor level - a measure of elevation from which to view the goings on of the council. I can place seating on the floor level, as you will see from the attachment, but when I try to place rows of seating on what is effectively the tread of the staircase it will be visible until such time as I click on something else and then it disappears. If I click on the space where it used to be it appears again but then vanishes when I move away. I have tried making adjustmentssing the object dialogue "height above floor" setting but it makes no difference. My thoughts were that using the stair tool would be far easier and quicker than fiddling about with soffits but it seems as if said thoughts were totally wrong. Is there some way that I can get the chairs to stay where I want them? Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 18, 2014 Share Posted September 18, 2014 Stair objects have a solid white "fill" which will tend to obscure other objects in plan view. Open each stair object and remove the "fill" making them "transparent" and that should solve your visual plan view problem. DJP Link to comment Share on other sites More sharing options...
Kbird1 Posted September 19, 2014 Share Posted September 19, 2014 did you uncheck the auto adjust height box on the chairs ? unchecking that allows me to set a chair any height I want off the floor .... not sure if your stairs are somehow effecting the height though? M. Link to comment Share on other sites More sharing options...
Keith_K Posted September 20, 2014 Author Share Posted September 20, 2014 Thank you. I will play with this issue once I have overcome the current new one. Link to comment Share on other sites More sharing options...
Solution Keith_K Posted September 29, 2014 Author Solution Share Posted September 29, 2014 Did what David suggested. It looked like a junk furniture store when all my attempts to place chairs were uncovered. Link to comment Share on other sites More sharing options...
