Landing in straight stairs
Koposet
Create two stair objects in plan view with the exact amount of space you require for your landing, then select the stair tool, left-click on each stair object and then left-click between the two stair objects. That action done as I indicate above will automatically create a landing between the two stair objects. This is true for any version and any title of Home Designer or Chief Premier software.
To duplicate existing stairs you would want to measure the depth of the treads, the number of treads and the exact height of the landings then, setting them exactly as the existing stairs. To do this you uncheck "Automatic Heights" and other "Automatic" stair settings and control the stairs manually. Takes a little more practice but gives you greater accuracy.
