BenDemir Posted June 11, 2017 Share Posted June 11, 2017 I'm doing a grading plan and typically there is an existing contour (elevations) then proposed (elevations). I was wondering if Home Designer Pro 2015 can perform this. I did find in the Tools>Display Options (Layer Display Options) [Terrain, Primary Contours] & [Terrain, Secondary Contours]. In the dialog box under Disp is checked but the plus sign is not present. I went through all the menus and was not able to locate this feature. The Primary Contours I know how to build, how do I build a Secondary Contour. Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 11, 2017 Share Posted June 11, 2017 Secondary contours are automatically produced when terrain is built and modulated. Once done they can then only be displayed or not via Layer display Options but they have to exist to be seen. (you have to build them first) DJP Link to comment Share on other sites More sharing options...
