briancaos Posted April 22, 2017 Share Posted April 22, 2017 It's wonderful that Architectural 2018 have addressed the issues with performance that 2017 had. But it seems that 2018 also handles roofing differently. Attached is a .zip file containing a funkis house. The house was started in Architectural 2017 and the plan works fine here. But when opened in 2018, most of the roof is missing. It seems to be an issue where 2 walls across each other cannot be of type "High Shed/Gable wall" Is this a bug in the new version, or is there a solution to the issue? Funkis_3.zip Link to comment Share on other sites More sharing options...
swarren Posted April 22, 2017 Share Posted April 22, 2017 (edited) Brian, when opened in 2018, I noticed the 2 soffits in the Master Bedroom closet were now above the ceiling. One of the new features as I understand it in 2018 is the ability to have different heights in rooms without resorting to soffits. Short Ceilings for Rooms within Larger Rooms. Create plant shelves, shorter closets, or other rooms that have a lower ceiling than the greater space and control the ceiling platform and materials automatically. Anyway, I used the dialog box for each soffit to bring it below ceiling height, and checked the interior view and did not see a problem. I then just extended the still existing roof plane over main house, and then the side plane. I then used the break line tool in roof planes to "cut out" the corner above the master bath. Whoops, left an unneeded attic wall. Removed it. Funkis_3_2018.zip Edited April 22, 2017 by swarren Not enough coffee. 1 Link to comment Share on other sites More sharing options...
Jo_Ann Posted April 22, 2017 Share Posted April 22, 2017 swarren, briancaos has Architectural, not Pro. Adjusting roof planes is not an option for him. 1 Link to comment Share on other sites More sharing options...
swarren Posted April 22, 2017 Share Posted April 22, 2017 Jo_Ann, you are correct. Sorry. I stand by not enough coffee. I have found some official sample plans have weird anomalies, such as soffits (or what I THINK are soffits) where you can't remove them, but they are there. I do believe the underlying video display software is vastly different from 2017 to 2018. 1 Link to comment Share on other sites More sharing options...
Jo_Ann Posted April 22, 2017 Share Posted April 22, 2017 briancaos, On floor 1, the south wall of the livingroom is marked "high shed gable". The north wall of the master bath is also marked "high shed gable". Remove that setting from the bath wall. 1 Link to comment Share on other sites More sharing options...
swarren Posted April 22, 2017 Share Posted April 22, 2017 Jo_Ann and briancaos, I think I remember now why I went from Architectural 2014 to Pro 2015. Having two high shed walls on opposite ends of a building does not make a lot of sense to me for a single roof plane. But that is indeed the case with the Funkis plan. And it works for 2017 but not 2018. I followed Jo_Anns suggestion to remove the high shed gable wall from the bath, and just let auto rebuild do the rest. Since I am using Pro 2018, that's about as close as I am going to get to Architectural 2018. The second story roof amazingly is fixed but the side 1st floor roof is now two planes (at least with Pro 2018). I tried removing the high shed gable from the living room too and things went really bad. Perhaps this is just another difference between Pro and Architectural. Kudo's to Jo_Ann for finding the high shed gable walls in the first place. I am glad this is just a hobby for me! 1 Link to comment Share on other sites More sharing options...
briancaos Posted April 22, 2017 Author Share Posted April 22, 2017 Hi Swarren and Jo_Ann, Swarren, your first solution does indeed fix the issue, but unfortunately the file is read-only for me, as I only have Home Designer Architectural 2018. Jo_Ann, unchecking the "high shed/gable" wall at the north wall does bring up the roof again, but this time in 2 planes. This was the issue that I solved in 2017 by having both ajacent walls as "high shed" walls. I guess there is a bug in Home Designer Architectural 2018 as I have other plans where the roof is messed when using "high shed" walls. Thank you for your time, it is very appreciated. Link to comment Share on other sites More sharing options...
swarren Posted April 23, 2017 Share Posted April 23, 2017 Brian, try saving the 2017 file with auto rebuild roof OFF in 2017, give it a new name just in case.. Open the new file with 2018 and see if it works. 1 Link to comment Share on other sites More sharing options...
briancaos Posted April 23, 2017 Author Share Posted April 23, 2017 Yes, indeed with the auto roofing OFF, the roof was saved. Again, thank your for your time, it's much appreciated. Link to comment Share on other sites More sharing options...
