Manual truss top chord extends beyond bottom chord
rfcomm2k
I manually built the trusses and have a problem with the top chords. The bottom of the bottom chord members rest on top of the double top plate for the walls. The top chord should end at the same place, but instead it is extending past the bottom chord. The bottom tip of the top chord member is exactly 14 1/2" below the top of the wall plates, but it should be flush with it. Also, the bottom chords do not extend beyond the walls, which is probably where the problem is but I cannot see how to adjust them. I tried unchecking "Trim To Soffis" but that did not help.
To describe it in another way, picture the ceiling rafters extending past the walls by the distance specified for the eave overhang (in this case 24"). Then the roof rafters END at the end of these ceiling joists in a plumb cut to which the fascia is attached.
I cannot upload a plan right now because this PC is NOT the same PC I am using for the software at this time.
OK, I see the box you are circling here. I set mine to 12", made sure the check boxes are as you have them, and clicked OK. I then clicked Build Framing Roof Truss, and added my first truss. It still turned out just like the one in the foreground of your pict.
I was not building or showing roof framing because I was using trusses instead. I purposely skipped the roof framing because I did not want to add additional material to the material list that was not required. But then, I never got around to checking how much material was being added. For all I know, maybe the TRUSS material is not even calculated. Will check that later.
Apparently I HAVE to build roof framing in order to build trusses properly.
I am almost there with the design, but the top chord of the truss still extends past the bottom of the bottom chord, but now only about 2.5"
No. You do need to build/rebuild the roof before drawing the truss.
The 12" raise may need to be adjusted, depending on your overhang. You can do the math, or just raise / lower a bit and then rebuild.
I drew a second structure in your plan and had the same problem as you.
I copied your walls into a new plan, and the trusses built correctly.
Guessing there is an incorrect setting somewhere. Try a new plan.
Don't build any framing, just the roof planes. Place a truss.
Tried restarting everything, including the PC. New plan, first thing done was to edit the defaults to set the rafter size to 5 1/2 instead of 9 1/4 and ridge to 9 1/2 instead of 11 1/4. Then clicked OK
Next was I built 4 exterior walls.
Then I clicked Build/Roof, checked auto rebuild roofs, changed raise/lower from ceiling to 12", left the eave overhang at 18" for now.. checked the box for build roof planes and clicked OK
Then I clicked Build/Framing/Roof Truss and drew in the first truss. I then did a wall elevation. The truss top chord extends below the bottom chord by 2". So I changed the Raise/lower from ceiling height to 14" and rebuilt the roof. I deleted the old truss and added a new one. IT WORKED!
So to test a theory, I changed the eave to 24" but left the raise/lower setting at 14". This time the top chord extends below bottom chord by 4". So I changed the raise/lower setting from 14" to 18" and it worked again.
So now I have an understanding about the relationship between the raise/lower setting and the eaves.
Thanks Eric for making me think about this and for your advice!
