material lists
bradcas
This software is completely mechanical and only "knows" what you tell it to do. So within the limits of its programming you can do what it is programmed to do. See Materials Lists section of the Reference Manual for specific information and procedures.
Please look under your "Tools" main menu "Materials Lists" for your various possible choices. Each of these commands do very specific and limited things when commanded and may or may not be what you need and want. All I am saying is "check it out" after study and practice to see if that helps you.
