NTWoodwright Posted January 16, 2017 Share Posted January 16, 2017 Hi, So I have set the defaults for the cabinet end panels as 3/4", but when I add them to a cabinet, they don't seem to increase the width of the cabinet or occupy 3/4" on my drawing. For example, if I have a 12" wall cabinet, and I add a right side panel using the cabinet settings, the cabinet length does not increase to 12 3\4", it remains 12". My panel defaults are 3/4" under the accessories. Can someone tell me what I am doing wrong? Thanks! NTW Link to comment Share on other sites More sharing options...
DCortes Posted January 16, 2017 Share Posted January 16, 2017 For others to better assist you please fill out your signature and post a copy of the plan. Link to comment Share on other sites More sharing options...
NTWoodwright Posted January 16, 2017 Author Share Posted January 16, 2017 Thanks guys. I think I updated my signature with the required info. Kay, so I have been you youtube, have scoured the knowledge base (to the best of my ability) and I just can't seem to find anything on it. But what you are saying is that a 3/4" panel, added to the cabinet through changing the cabinet settings, will not increase the cabinet width. Right? I can either make the cabinet 3/4" wider, if I am adding a panel OR I can create a 3/4" wide cabinet with a panel added and all other features removed, correct? Just want to triple check;) Link to comment Share on other sites More sharing options...
NTWoodwright Posted January 16, 2017 Author Share Posted January 16, 2017 While I am here, I am wondering how I can get the point to point dimensions to let me select small items like partitions and panels. I can't select them when they are 3/4". Thanks! Doc3.docx Link to comment Share on other sites More sharing options...
NTWoodwright Posted January 16, 2017 Author Share Posted January 16, 2017 Okay, thanks! Link to comment Share on other sites More sharing options...
