alaska_av8r Posted August 21, 2014 Share Posted August 21, 2014 I am at this moment quite brain dead from watching videos and reading to try and find out how to solve my problem. I did figure out how to do this in HD 7 but lost all the files due to a hard drive failure. I just upgraded to Architect and am in the process of starting this all over. My house is a steep roofed A frame style, but the roof begins at the top of the first floor (not close to the ground like some A frames). The pitch is like 12" in 12". The house has a crawlspace withe a garage added later that sits on a slab. On the first floor the area over the living room is a cathedral ceiling, the hall located between the storage and living room is actually going to be stairs to the second level. The stairs begin in the hall and go to a landing at the exterior wall then turn 180 deg and go up to the second floor. This area is left open with a railing and view down to the living area. To the right is the door to the master bedroom. Entering the master bedroom the bath is to the right, then to the left is a small hall to a walk in closet above the garage. The problem i am having is that I cannot define the rooms on the second floor, every time I attempt to add a wall, invisible wall, anything it totally screws up the roof. The roof is almost 95% exact as it appears on the house right now. As you can tell I have no floors on the second floor except for the bath which I was able to define without screwing up the roof. I even downloaded some samples and tried to figure out what they did but have been unsuccessful. Any help will be appreciated, thanks in advance! Tim Link to comment Share on other sites More sharing options...
Solution DavidJPotter Posted August 21, 2014 Solution Share Posted August 21, 2014 Turn off auto-rebuild roofs, once roofs are where you need them to be. With auto-rebuild roofs "on" the software assumes you are not finished and treats all new spaces as new rooms. Where you intend to add living space under existing roof planes that is how it is done unless you redo the roofs which is very expensive to do, filling in under existing roofs is less expensive so you have to control the software so it does just what you need and want. DJP Link to comment Share on other sites More sharing options...
alaska_av8r Posted August 21, 2014 Author Share Posted August 21, 2014 I have attached a labeled version of the second floor that may help as well, you can see the stairs, I have a large beam that forms support for the second floor where it overlooks the living area. The upper landing and sitting area has railing shown in green. Link to comment Share on other sites More sharing options...
alaska_av8r Posted August 21, 2014 Author Share Posted August 21, 2014 Oh wow David, thank you for a quick response at such a late hour. You have renewed my energy so I will give that a try, may not get to sleep tonight at all. thank you tim Link to comment Share on other sites More sharing options...
alaska_av8r Posted August 21, 2014 Author Share Posted August 21, 2014 David you are a life saver! I have fretted with this for over 5 hrs and it was that simple....lol Link to comment Share on other sites More sharing options...
Kbird1 Posted August 21, 2014 Share Posted August 21, 2014 What you are doing is basically a storey and a 1/2 structure ( Cape Cod ) and the KB Article on those is pretty good : http://www.homedesignersoftware.com/support/article/KB-00358/52/Home-Designer/Roofs/Automatically-Building-a-One-and-a-Half-Story-Roof.html http://www.homedesignersoftware.com/support/article/KB-01036/52/Home-Designer/Roofs/Stopping-the-Roof-from-Automatically-Rebuilding.html M. Link to comment Share on other sites More sharing options...
alaska_av8r Posted August 21, 2014 Author Share Posted August 21, 2014 thank you kbird I will have a look at those. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 21, 2014 Share Posted August 21, 2014 happy to help if I can , post again if you have specific issues ...pics of the problem help a lot.....a 1000 words and all that M. Link to comment Share on other sites More sharing options...
