gu4u22 Posted October 24, 2016 Share Posted October 24, 2016 Hello, I spent a lot of time making an elevation profile of my very-hilly lot (see attached picture). Home Designer imported that with no problem. My question is regarding moving the house within the lot. I cannot seem to find a way to only select the house, so every time I try to move it, I end up moving the elevation points, which screws up the elevation. Can I send the elevation points to a different layer but still make the elevation profile visible? The most import thing for me right now is to be able to nudge the house to be "just right", but I have to see the elevation profile for that. How can I do it without selecting the elevation points below the house? Best, Gustavo Link to comment Share on other sites More sharing options...
solver Posted October 24, 2016 Share Posted October 24, 2016 See if you can Lock the elevation data layer. Link to comment Share on other sites More sharing options...
gu4u22 Posted October 24, 2016 Author Share Posted October 24, 2016 See if you can Lock the elevation data layer. How do I lock the elevation data? Link to comment Share on other sites More sharing options...
solver Posted October 24, 2016 Share Posted October 24, 2016 Layers dialog. Link to comment Share on other sites More sharing options...
gu4u22 Posted October 25, 2016 Author Share Posted October 25, 2016 Layers dialog. Hello Solver, I tried to lock the elevation layer (Terrain, Elevation Data). When I use the Edit Area (All Floors) to move the plan, it still moves the elevation points even though they are locked. If I use the Edit Area (All Floors) Visible, it keeps the elevation data in place (which is good) but it does not move all I need. Any help? Best, Gustavo Link to comment Share on other sites More sharing options...
Solution gu4u22 Posted October 25, 2016 Author Solution Share Posted October 25, 2016 Hello Solver, I tried to lock the elevation layer (Terrain, Elevation Data). When I use the Edit Area (All Floors) to move the plan, it still moves the elevation points even though they are locked. If I use the Edit Area (All Floors) Visible, it keeps the elevation data in place (which is good) but it does not move all I need. Any help? Best, Gustavo Ok, I found the answer. I checked every feature to display except for the elevation data. I then used the Edit Area (all Floors) Visible to move the plan. It worked. Link to comment Share on other sites More sharing options...
