gu4u22 Posted October 4, 2016 Share Posted October 4, 2016 Hello everyone, I'm having a problem with one of the walls of my overhanging structure. While one wall is sitting exactly where it is supposed to, on top of the beam below, the other is sitting on top of the deck. I can't seem to be able to move the structure below so it supports the wall. Please see the attached cross-section view for more clarity-the problem wall is on the right side of the cross-section circled in red. Thanks in advance. Gustavo Help_Plan_2.plan Help - Home Designer_10-4-16.pdf Link to comment Share on other sites More sharing options...
DavidJPotter Posted October 5, 2016 Share Posted October 5, 2016 I looked at your PDF and plan file and I cannot figure out what you are talking about, can you be a little more specific? DJP Link to comment Share on other sites More sharing options...
gu4u22 Posted October 5, 2016 Author Share Posted October 5, 2016 I looked at your PDF and plan file and I cannot figure out what you are talking about, can you be a little more specific? DJP Thanks for looking at this again David. Take a look at the attachment illustrating what I need to move. Best, Gustavo Help - Home Designer_10-4-16_v2.pdf Link to comment Share on other sites More sharing options...
Solution gu4u22 Posted October 5, 2016 Author Solution Share Posted October 5, 2016 Thanks for looking at this again David. Take a look at the attachment illustrating what I need to move. Best, Gustavo Hello again David, I just solved the problem. Under the Deck "Structure" menu, I had the box "Floor Supplied by the Foundation Below" checked. When I unchecked it, the Deck moved out of the way, so I just rebuilt the overhang floor again and all is good. Thanks again for the help on this. Best, Gustavo Link to comment Share on other sites More sharing options...
