Foundation problems with a house on a hillside.
gu4u22
Go to solution Solved by DavidJPotter,
Hello,
I am stuck on this for several days. I'm designing a house on a hillside that is partially supported by a concrete slab and partially supported by posts, jetting out of the hillside (see pictures). I built the slab portion with no problems, but I cannot get the software to build the framing of the floor of the portion that will be supported by the posts. I have already looked at the "Creating a Structure that is Built on Piers" tutorial, but that technique doesn't seem to help a more complex terrain such as the one at hand. Do I need to build the frame manually or is there an easier way?
Any help would be greatly appreciated.
Help - Home Designer.pdf
Hello David,
I cannot thank you enough for looking over my plan. What I was missing was the change of "material" for the floor structure. I thought that function was purely cosmetic.
By the way, the walls I had on the basement level was an attempt to force the software to build a frame above it.
Now I just need to find out what that white sheet of material below the overhang is.
Thanks again,
Gustavo
