6271981 Posted August 14, 2014 Share Posted August 14, 2014 I am building plans for an over-sized garage. I want doors to be 12 feet tall for RV use. It seems like changing wall 'height' should be a menu choice, but I can't find it. It should be straight forward. How do I change wall height to accommodate taller garage doors? Thank You Bob in CO Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 14, 2014 Share Posted August 14, 2014 If you require a high ceiling in any sort of room you go to that Room Dialog box-Structure tab and set the finished ceiling to the height you require, you then place the garage door or doors and re-size them to suit your purposes using the door dialog box DJP Link to comment Share on other sites More sharing options...
