Darren Posted June 14, 2016 Share Posted June 14, 2016 Hi All A bit confused on how best to remove internal wall claddings from only 3 rooms in a plan. What I want to do is show the builder a walk through and in the copy I want to provide him the home theatre, studio and garage should be bare stud walls but the other rooms should be correctly showing the walls Basically I'll do those room builds myself rather than get the builder to do it... Darren Link to comment Share on other sites More sharing options...
English Posted June 14, 2016 Share Posted June 14, 2016 Make the one wall that will retain the sheetrock a different style from the others. Then edit the three wall style and remove the sheetrock. Alan Link to comment Share on other sites More sharing options...
katalyst777 Posted June 14, 2016 Share Posted June 14, 2016 In Architectural, you'll probably have to fake the look with Post to Beam (no rail) Railings with the spacing set to 24" apart or so. 1 Link to comment Share on other sites More sharing options...
