Full Gable Wall
lmorris
It helps if we know what title (Suite, Pro etc) and version (2014, 2015 etc) you are using. You can add this info to your signature by clicking on your user name at the top right of the page, click My Settings, then Signature on the left.
Resources for self help:
In any version or title you toggle up to the <A> or attic level, find the attic wall you wish to edit, then open its dialog. Go to its Materials Tab and then change the exterior material to the one you wish. If your software has a "Pony-Wall" tool you can further split the attic wall into two separate sections and assign different materials to the two halves using the "Wall Specification Dialog". That only works if you have Architectural or Home Designer Pro. The prior advice works with any title or version.
