recessed wall
magabuddy
I'm trying to achieve the recessed wall under the window as shown.
I also put a screenshot of the window I have put into my progect.
How can I achieve that space so that I can put the radiator? Thank you!
Here is a plan that should get you started.
Use a doorway with no casing to make the opening so you can see the window from inside.
You can use a Soffit to make the shelf above the radiator.
Also, questions should go in the Q&A area, not Tips & Techniques.
It helps if we know what title (Suite, Pro etc) and version (2014, 2015 etc) you are using. You can add this info to your signature by clicking on your user name at the top right of the page, click My Settings, then Signature on the left.
Resources for self help:
