How can change an object (grab bar) from horizon to vertical or slanted
12345kayun
You do not, that can only be done in Chief Architect Premier unless you are talking about a Sketchup grab bar which can be rotated or edited in Sketchup and then reimported into Home Designer. Have you checked for additional library catalogs available at the Home Designer Website? 3D Warehouse and then download and import?
