Jim_Brown Posted December 13, 2015 Share Posted December 13, 2015 I am modelling an existing house. After I got the roof planes looking correct, I realized that the pitches were wrong. I was using the 8/12 default, but the house actually has a 10/12 roof. Attachments "Shallow Roof.jpg" and "Shallow Roof 2.jpg" show the design with roof pitch set to 8/12. Although this is the right shape, the rooms under the roof are not as high as the actual house. When I raise the roof pitch, I expect to increase the height of the dormer-like structure to keep it aligned with the peak. Instead, this is what I get - see files "Steep Roof.jpg" and "Steep Roof 2.jpg". Nothing I do seems to help. I can successfully increase the pitch to about 9/12 but no further. Any suggestions? Let me know if more files would be useful. Thanks PS - i have enabled Signature, but I don't see it in the preview. I am using HD Suite, 2016 on a Windows 7 computer. Link to comment Share on other sites More sharing options...
solver Posted December 13, 2015 Share Posted December 13, 2015 When you have structural problems especially, it's best to post the plan file as well as pictures. Make sure it's closed before posting. Make a copy of the plan. Go to the Build Roof dialog and change the pitch to 10. Go to Edit>Default Settings>Floor and make sure your ceiling heights are correct. Do this for both floors -- in plan view, go to floor 1 and then set defaults, got to floor 2 and set defaults. Go to Edit>Reset to Defaults. Select All Floors and check all the options. Build the roof. Go around the plan changing walls to Full Gable and changing the pitch as needed. This should get you to a default build, although I suspect there will be problems with the second floor roof. Resources for self help: The built in Help System (always a good place to start) Getting Started Knowledge Base YouTube Link to comment Share on other sites More sharing options...
Jim_Brown Posted December 14, 2015 Author Share Posted December 14, 2015 Eric - Thanks for your assistance. None of your suggestions has made any significant change to my roofs. I have attached my plan so you can see more details. I have had to zip it, even though the original is less than 3 MB. 87 Thompson Roof.zip Link to comment Share on other sites More sharing options...
solver Posted December 14, 2015 Share Posted December 14, 2015 Go to the second floor. Select and copy the 4 walls that create the room. Delete the second floor. Go through the steps to reset, then change wall and roof directives outlined above. The settings for the front wall should look like this. Build a blank second floor. Paste>Paste Hold Position to put the walls back. Change the Rough Ceiling to 104 3/8". Back to the front wall on the first floor. Uncheck Upper Pitch. I have no clue why, and there may be an easier way. Link to comment Share on other sites More sharing options...
Jim_Brown Posted December 17, 2015 Author Share Posted December 17, 2015 Worked! Then I immediately unchecked Auto Rebuild Roofs. I have to say that I am not impressed with this software. As a one-time software engineer, I would rate it as not ready for the market. I am happy that people like you have spent the time needed to understand its idiosyncracies and are willing to help people like me (newbies) who haven't yet spent the time needed to learn what we need to know. Thank you Link to comment Share on other sites More sharing options...
solver Posted December 17, 2015 Share Posted December 17, 2015 I have my own issues with the software too, but remember, you chose the $100 version. There is a reason that Pro is $500 -- it does more. Link to comment Share on other sites More sharing options...
Jim_Brown Posted December 19, 2015 Author Share Posted December 19, 2015 I would expect a $500 version to do more. But the $100 version should do what it does in a predictable, repeatable manner. I don't see anything predictable about the problems I had, nor the solution you discovered. Link to comment Share on other sites More sharing options...
