alisonclaire Posted December 12, 2015 Share Posted December 12, 2015 Hi - hoping someone can help. I am using Home Designer Pro and am self-taught. For some reason, when I place an exterior/front door in a wall, it is set back from the Exterior wall and the floor from inside can be seen. I have switched off 'recessed' but cannot get it to move forward.....why is this and what can I do? HELP! Alison Link to comment Share on other sites More sharing options...
LawB10 Posted December 13, 2015 Share Posted December 13, 2015 Try changing the swing side. Link to comment Share on other sites More sharing options...
RichT66 Posted December 14, 2015 Share Posted December 14, 2015 This is very similar to my post from 11 December titled controlling door recessing.. It would appear that an inward opening doors always end up on the inside of the main layer, even when you select non recessed. The only way I found was to make the door open outwards but then this makes the floor plan incorrect. If you opt for a swing both ways door (!) you can get it in the middle of the main layer. It's a shame there's no inset option as there is for windows! Link to comment Share on other sites More sharing options...
