LenB10p Posted November 27, 2015 Share Posted November 27, 2015 Apologies if this already exists somewhere, but the only examples I've found thus far don't show how to "drag and drop" a dormer on a roof in HD Suite 2015. I have a basic two floor design and want to have some dormers on the second floor. Can someone please point me in the right direction? Thanks Len Link to comment Share on other sites More sharing options...
LawB10 Posted November 27, 2015 Share Posted November 27, 2015 Here's an example of a dormer, the dormer has to fit inside the roof pane. Draw a room, use the dormer tool and apply to any one of the roof panes to get an idea of how it works. Link to comment Share on other sites More sharing options...
Solution LenB10p Posted November 28, 2015 Author Solution Share Posted November 28, 2015 Thanks...what I need to do is resize the dormer if the roof plan is slightly too small to fit the auto dormer into. I've looked at the tutorial for HD Pro on manually creating dormers, but don't know if this works in HD Suite 2015. The auto dormer tool is fine, but you can't make it smaller...only wider or narrower...but not shorter. Unless I'm missing something. I'll keep searching for options. Len Link to comment Share on other sites More sharing options...
LawB10 Posted November 28, 2015 Share Posted November 28, 2015 If it's to big for roof pane, then open the specification box, resize the height and/or pitch. Here is some examples: The first one is 30" high then 20" 10" 5" Link to comment Share on other sites More sharing options...
