3D rendering problems
jrubis
Go to solution Solved by DavidJPotter,
I have started to experience an issue with 3D rendering in my project. It appears that the outer most skin or layer of an object is transparent. Note in the attached image, you can see the OSB beneath the shingles in places. I have attempted to adjust the render options but that didn't fix it. I also tried opening the file on another machine and observed the same problem. Any thoughts?
Using HD PRO-16​
  • Downvote 1
Dave,
Thanks again for the help! It apears that was the problem. I had house's setback on lot pretty far. I move the home closer to the front of the lot (terrain model) and the issues went away. I also tried to adjust the Default camera clipping distance to 300" from 24" as suggest by the post you linked to, that worked as well.
