Make Parallel Tool Button?
jrubis
Go to solution Solved by jrubis,
In Pro 2016 the parallel-perpendicular tool will appear when you select any object (left-click-select) or when you right-click select an object. the tool icon then appears along with others in the "Edit Toolbar". When you deselect any object the "Edit Toolbar" then vanishes until another object is selected. The icon looks like two parallel lines drawn perpendicularly to a third line.
