BrianS Posted October 9, 2015 Share Posted October 9, 2015 Hello, I live in an area where concrete block walls are standard for exterior walls. However, the plans also need notate the exact location of each vertical downrod/rebar. On most blueprints, they are noted by a 6" x 6" +/- black square in the wall assembly of the floor plan each place the rebar is to be located. A similar box is also on the foundation layout. How is that accomplished with Home Designer pro, or Chief Architect Premier. Thanks, Brian Link to comment Share on other sites More sharing options...
DavidJPotter Posted October 9, 2015 Share Posted October 9, 2015 CAD tools - Closed Poly-Line with a solid fill sized to 6" x 6" (in Premier you can place such objects on a custom layer making it easier to turn on and off at needs, in Pro you cannot) DJP Link to comment Share on other sites More sharing options...
