Deck Pier Posts
MattJohnson_OC
Go to solution Solved by MattJohnson_OC,
I opened my copy of Architectural 2014 and the only way I could control the posts was to paint each one with "Opening No Material" because they cannot be otherwise selected or edited. Painting them with "Opening No Material" makes them disappear one at a time, just be sure you use the "Component Mode" of the "Material Painter tool" and do not use the paint roller tool to do so. That way you can at least control the number of posts that is showing in camera views.
