Markdownunder Posted August 23, 2015 Share Posted August 23, 2015 Hi all, I am on HDP and need to set the default "room label" dimensioning to round up to the nearest centimetre, is this possible? I have attached an image. Thanks in advance... Link to comment Share on other sites More sharing options...
solver Posted August 23, 2015 Share Posted August 23, 2015 Have you studied the Help system search results for Rounding? Link to comment Share on other sites More sharing options...
Kbird1 Posted August 23, 2015 Share Posted August 23, 2015 I usually turn them off in Display Options but I am not actually sure you can alter those numbers , AFAIK the Rounding Options under Dimensions are for Dimension Strings Only. M Link to comment Share on other sites More sharing options...
Markdownunder Posted August 23, 2015 Author Share Posted August 23, 2015 Mick correct, it only rounds the dimension strings not the dimensions on the Room label Link to comment Share on other sites More sharing options...
