Roof for a Second Structure
Hoosier_Daddy
Hi HD , I see you made it over here :)
Please fill in your Profile signature , (see mine for a how too)  and let us know who you are and what software and Version you are using , different titles have different abilities and thus difference answers to Questions. Thx.
All Roofs have to be Built at once in Suite , not sure Why it would "jack it up" unless you added another Floor though , so best to post the Plan file here , make sure the plan is closed in HDS 1st though or it wont post....no need to zip it unless it is more than 25mb.
The problem is you cannot auto build your roof anymore.
You will need to go back to where you can. I suspect resetting your ceiling heights on the second floor will do it.
Once that is done, you should be able to turn auto build roofs back on, and the roof on the house will build correctly.
Then add the pool house.
Make a copy of your plan file to work in.
