Ginger Posted June 22, 2014 Share Posted June 22, 2014 In HDP, are you able to save the project as a HDA version so that it can be open (and edited) in HAD? I am sure that this has come up before, apologies if it has, I did look for it first. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 22, 2014 Share Posted June 22, 2014 The versions have to be the same Year or newer ie Pro 10 can open older but not 2012,14 or 15 plans , but not sure there is any restriction between titles in the same year. someone may correct me on that M. Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 23, 2014 Share Posted June 23, 2014 I created a plan in Pro 2015 and then opened in in HD Architect 2015. I got an automated message that I could view but not edit the Pro plan in Architect. I then created a plan in HD Architect 2015 and then opened that plan in HD Pro 2015 and it merely opened. So the answer is you can share witl Pro 2015 plans made in other 2015 software titles but plans created in Pro 2015 can only be edited in another seat of HD Pro or Chief Architect Premier. Once a plan started in anything but Pro gets opened and saved, it can no longer then be edited in anything but Pro or Chief Premier. DJP Link to comment Share on other sites More sharing options...
Kbird1 Posted June 24, 2014 Share Posted June 24, 2014 Hi David , Does the Room Planner App work with HD Titles? could it be used to View / edit files? Can any HD Title import Room Planner Files or is Room Planner For Chief titles only? Thanks M. Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 24, 2014 Share Posted June 24, 2014 Hi David , Does the Room Planner App work with HD Titles? could it be used to View / edit files? Can any HD Title import Room Planner Files or is Room Planner For Chief titles only I do not have a smart phone and have not used "Room Planner", that is a good question for "Sales Chief Inc" though. DJP Link to comment Share on other sites More sharing options...
