DevonBabineau Posted May 10, 2014 Share Posted May 10, 2014 How do you share plans between devices and people? If you share your plan on your IPad in icloud, how do you open it on your laptop? The version I am using is HD Pro 2014. Thanks Devon Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 10, 2014 Share Posted May 10, 2014 In order to open a ".plan" file you must have HD Pro 2014 installed on the other divice. If you want merely to share views of a plan, I commonly print views to PDF using "CutePDF" and then anyone who has Adobe Acrobat Reader can then view the file and print the PDF to paper at scale if you like. I think that printing to PDF is the easiest way to share views. DJP Link to comment Share on other sites More sharing options...
Kbird1 Posted May 11, 2014 Share Posted May 11, 2014 don't have an Ipad but I guess you are using Room Viewer I think its called so you would need that app on the Laptop as well or Have HD Pro installed on it....At this point I think the App is only available for Ipads and Iphones though. ( sorry don't have either)<br /><br />Other than that there is the PDF route mentioned..I use PDF995 (came with Pro10) or I just Export .jpgs images ( or .png) and share Images that way via email/ The Cloud etc.<br /><br />M. Link to comment Share on other sites More sharing options...
