piece out of the roof
pvdveen
Go to solution Solved by pvdveen,
Peter, I would need to know where you want part of the roof removed and why in order to help you. Generally speaking, Home Designer Pro would made such a job easier, where as in Architectural, you have fewer choices.
In Architectural you can create a "skylight" which cuts a hole in the roof and then by using its dialog, change it into a "hole" only (every object in the software will have a dialog where some alteration is possible.)
  • Solution
David,
The skylight did the trick for me. I could not find the option to change it into hole only. But I changed al the materials to glas and that is good enough for me to get a impression.
Thanks for your help.
