EdHusky Posted June 28, 2015 Share Posted June 28, 2015 (edited) i have added many windows, all show in the perspective full view except one window. it shows in the wall but when i use full camera view, the window shows not the outside but shows the fiberboard on the exterior wall through it. how do i correct this? i'm at my wits end as I've tried everything. The window is on the second floor in the walk in closet. thanks for the help. I am using CA Suite 2016 v17.3.0.25OSX house7 small contem 2 floors.plan Edited June 28, 2015 by EdHusky Link to comment Share on other sites More sharing options...
Kbird1 Posted June 28, 2015 Share Posted June 28, 2015 I'm with Eric Ed , in weird case like this , posting the plan is the quickest way to get an answer. you could try rebuilding the framing ,so it updates , incase it hasn't yet around that window. ( which will remove the OSB too) Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 28, 2015 Share Posted June 28, 2015 If your structure is two-story AND the upper walls are out of alignment, one floor to another, IF this is the case then that could be the cause of covering up windows that show in plan view but not in camera views. Check for that and see if it helps. DJP Link to comment Share on other sites More sharing options...
Solution EdHusky Posted June 28, 2015 Author Solution Share Posted June 28, 2015 Hi David, you nailed it. the first and second floors were slightly out of alignment. corrected it and the window now shows. THANK YOU FOR THE HELP !!! Link to comment Share on other sites More sharing options...
