Building a Portico
apex944
I followed the CA info on how to add a Portico found here: http://www.homedesignersoftware.com/support/article/KB-00168/
However the Portico I want to design does not use a gabled roof.
Attached is a photo of what I'm trying to do.  Flat "roof" with a balcony on it.
If I can get the roof created the balcony I can create.
The porch slab, columns all were created.
It's the flat roof I'm having trouble with.
Pointers?
yes I'd try putting the railing walls right over the Porch walls and make sure you assign Balcony to the second floor Room
you could also turn off the roof in the Porch below
If you attach the plan Jo or I or someone can have a look for you.
THEN......I would designate that room as a 'slab' if you want the floor surface to be lower than the roof surface..    If you want the floor surface to be flush with the roof surface, I would make the floor finish (k) to be 6".
On the 1st floor room, check 'ceiling over this room' and 'use soffit surface for ceiling'.  I would then increase the ceiling finish (j) to 6".
How does it look?
It open each of the 3 walls, and under the 'roof' tab, set the pitch to 0.
That should fix it.
That was it.  The Portico instructions I found specified a gabled roof.  Removed that and the pitch setting was then available for editing.
Thank you.  :)
Any insight into my dimension constraint question a few posts down?
