in need of some help for a raised platform for a wood burning stove
selectbuilder
Hi Jon,
Which software title and version do you have?  If you have HDPro, you could use a slab and apply a tile texture to it.  If you have the ability to use a soffit, then you can use one of those in the same fashion.  If neither of those work, and you have a box shape in your shapes library, then again, use that with the appropriate texture applied.
Good luck. :)
