Moose13 Posted August 10 Share Posted August 10 Good afternoon - I want a deck with the decking going in 2 directions. The attachment shows a deck with arrows showing the direction I want the boards to run. They'll meet at a parting board (the 45 degree line). Is that possible? Thank you......John Link to comment Share on other sites More sharing options...
Rookie65 Posted August 10 Share Posted August 10 Yes. Put a room divider going diagonally at the corner. Then check the defaults to make sure your joists are going from the house out. The decking will be perpendicular to the joists. Link to comment Share on other sites More sharing options...
