jfarris Posted August 9 Share Posted August 9 Seems like this should be easy, but I can't seem to figure it out tonight. How would I add a bench into my tile shower ? Essentially, I just need the cube, then i could add the surrounding tile as the texture. Thanks! Link to comment Share on other sites More sharing options...
y-g-m-n Posted August 10 Share Posted August 10 3d Shapes work well. you can also use soffit, slab, etc. basically anything that you can change the floor plan shape to suit and then locate bottom with reference to floor and change the height and finally material which you then change to match you tile. I 1 Link to comment Share on other sites More sharing options...
