Mike94 Posted Sunday at 03:18 PM Share Posted Sunday at 03:18 PM Trying to create my perimeter on a five-acre lot. How can I add the length of each side and adjust the proper north/south orientations? Mike Link to comment Share on other sites More sharing options...
y-g-m-n Posted Monday at 11:34 AM Share Posted Monday at 11:34 AM Change the way that angles are displayed by clicking On NUMBER style in lower left corner of just about ever EDIT Screen that you open up. Change to Surveying units AKA quadrant bearing - See that it loks like what is on your plot plan. So click on something and then click edit. Then what I do is draw each line by themselves and then move them to connect. Tried it as one unit and you have to pay attention wo that is staying fixed, start end etc etc. became a PIA found it easier to draw each line then move to connect then using the Point to Point move. So end point of one line click it and move it to the other line where it connects. Then when all done or before you need to draw in the NORTH POINTER Under CAD drop down menu Look it up in HELP If you do not add N pointer it makes NOrth vertical UP on screen. Add pointer you can rotate line so that your house is square to screen and easier to draw. they did not make it easy for sure. Link to comment Share on other sites More sharing options...
