HappyHausStudios Posted May 18 Share Posted May 18 I'm having trouble determining if my cabinet placement is accurate or if I need to manually enter a 2" filler near walls. Would I use the 'partition' for this? I'm using frameless eurostyle fronts. Link to comment Share on other sites More sharing options...
HappyHausStudios Posted May 18 Author Share Posted May 18 Appears to create a filler when I manually move a cabinet a couple inches away from the wall. Is this the correct placement approach? Link to comment Share on other sites More sharing options...
y-g-m-n Posted May 19 Share Posted May 19 yes Program will join a cabinet to anything that is 3" or less away. So you can space cabinets apart and it will add the filler Link to comment Share on other sites More sharing options...
