AFedBrost Posted Thursday at 10:57 PM Share Posted Thursday at 10:57 PM So I've been working on a shop drawing, and all the walls on the 2D floor plans, and even the cross sections look normal, but along the way my siding dissapeared? There's no steel siding material on my elevations or camera, and even on the camera view it only shows what looks like the OSB boards & the "Tyvek wrap". There's no framing components, vapour barrier or siding showing. What's going on? How do I fix this without completely re-drawing my walls? I've done so much work on it, it would be a mess to restart. Link to comment Share on other sites More sharing options...
y-g-m-n Posted yesterday at 06:41 AM Share Posted yesterday at 06:41 AM maybe check what layers are turn on to be visible in the 3d scree. Link to comment Share on other sites More sharing options...
AFedBrost Posted 11 hours ago Author Share Posted 11 hours ago Somewhat of a solution; I went in and checked on all the display options. This showed the siding but it was in very small strips, only where the framing studs were on the inside. I had to manually click and enlarge the siding layer to fit the wall. Then I went into my wall types, with the siding layer selected, I disabled the "framing" box in the "Materials Properties" tab and that seemed to help a lot more. Still not sure what I did to cause the issue. Link to comment Share on other sites More sharing options...
