TheMadCadder Posted 6 hours ago Share Posted 6 hours ago My first major glitch...anyone have an idea why the exterior siding shows in this one window in the attached image? Link to comment Share on other sites More sharing options...
Rookie65 Posted 4 hours ago Share Posted 4 hours ago A wall likely auto-rebuilt. Copy the window location, then check the walls to see if one or more says "Polyline produced by 3D wall editor." Delete it, and If you go too far, the wall you need will disappear. Then just just back up a step to put it back. Then you should be able to place the window you copied back. Sometimes the walls could be misaligned too. Without a plan to look at, it's just guesswork at this point Link to comment Share on other sites More sharing options...
