Plat and Layout integration
ANewViewforYou
  • 6 months later...
On 1/20/2026 at 4:07 AM, y-g-m-n said:
Better to draw so you can set it as terrain boundary
@ANewViewforYou:  You can import the plat into your plan as an image or PDF, then scale and rotate it as you like, then trace over it to create the Terrain Boundary.  Then if you really want to get fancy you can add the terrain elevation data so your 3D renderings and elevations are realistic.
