UCBD317 Posted July 30, 2025 Share Posted July 30, 2025 Hello! I am Home Designer Pro 2025, and I am a beginner. I am trying to change dry wall from the default 96" to 144". I went to edit -> default setting -> Walls, and edited the wall types (define, dry wall, double click to change material) for both exterior and interior walls. When I do the list of materials, I see both 96" and 144" dry walls listed in the wall board. When I select the 96" and do right click to find object in plan, the entire inside area of the house is grayed out. Is there anything I am missing / not considering? Thank you for any help! Link to comment Share on other sites More sharing options...
y-g-m-n Posted July 30, 2025 Share Posted July 30, 2025 do not think there is a way. Should only affect the material list when you calc for rooms, floor or house.. List gives # sheets so you could do a little math - take: #sheets * 8/12 = Q12ft you need Link to comment Share on other sites More sharing options...
UCBD317 Posted July 31, 2025 Author Share Posted July 31, 2025 Thank you! Link to comment Share on other sites More sharing options...
