mhth0727 Posted July 22, 2025 Share Posted July 22, 2025 I'm working on a plan, I have a front porch with a gable pitch. I remove the ceiling so the top is open but I'm wanting to add a truss to the front to see how that would look. When I go up to Build there is no framing option. I was trying to follow this https://www.homedesignersoftware.com/support/article/KB-00417/creating-exposed-trusses-in-home-designer-pro.html?srsltid=AfmBOoo-adl8vjGpiIO3EYpi9rySsEP6Ypj0CBpwyTX8v7ZxME2Wg4CB but it's older and my software does not have these options. Is this just not possible with what I have or is there a way to achieve this that I am not seeing directions on? Link to comment Share on other sites More sharing options...
RoyJames Posted July 23, 2025 Share Posted July 23, 2025 That resource unfortunately only applies to Home Designer Pro and does not work for Home Designer Suite. To create decorative finishes, you might use some of the techniques shown in the following article: https://www.homedesignersoftware.com/support/article/KB-00902/applying-exterior-decorative-details.html I hope this helps! Link to comment Share on other sites More sharing options...
